Author Topic: how to control LTDZ MAX2870 23.5-6000Mhz signal source?  (Read 1208 times)
Offline biastee
  • Country: my
    • 9W2LC
« on: December 07, 2021, 05:15:00 am »
I bought a "LTDZ MAX2870 23.5-6000Mhz signal source" (attached image), which is available from all the major online platforms.  However it didn't come with any instruction.
There are 5 tact switches on the PCB, covering the following functions: <, >, ^, v, and OK. I can change the frequency thru these switches, but for the life of me, I can't figure out how to manually change the amplitude. In the attached photo, the amplitude is displayed on the bottom row of the display.
There is a frequency sweep function, but I can't figure how to start the sweep.
According to the advertisement, the item can be PC controlled, but no software is provided. When I tried to connect with the MAX287X PLL EV Kit Software, it couldn't detect the signal source (error message in attached image below).
Thanks.
[attach=1]
« Last Edit: December 07, 2021, 05:20:07 am by biastee »
Online ledtester
Re: how to control LTDZ MAX2870 23.5-6000Mhz signal source?
« Reply #1 on: December 07, 2021, 07:48:45 am »
A couple of things...
Banggood sells the same device:
https://www.banggood.com/Geekcreit-LTDZ-MAX2870-STM32-23_5-6000Mhz-Signal-Source-Module-USB-5V-Power-Frequency-and-Sweep-Modes-p-1696744.html
and if you follow the link >>>Instruction: Click here to open<<< it brings you to this low-level protocol documentation:
http://myosuploads3.banggood.com/products/20200618/20200618202558MAX2870STM32RF.pdf
Also, Tony Albus has both the ADF4351 and MAX2870 versions, and in this video he shows the same control program operating both the ADF4351 and MAX2871 (at time 21:29):
#129 MAX2870 LCD Signal Generator vs ADF4351 LCD Review Teardown -- Tony Albus
https://youtu.be/DFtC7icVr-E&t=21m29s
and he thanks the ebay store "pincei_de" for the control software:
[attach=1]
Tony is also on this forum (username "tonyalbus"), so you might contact him.
The MAX2870 and ADF4350 are very similar -- here's a Maxim app note comparing the register layout in both devices:
App Note 5498 - Comparing the Registers and Loop Filter of the MAX2870 and ADF4350 Synthesizers
https://pdfserv.maximintegrated.com/en/an/AN5498.pdf
« Last Edit: December 07, 2021, 07:52:15 am by ledtester »
The following users thanked this post: edavid, biastee
Online ledtester
« Reply #2 on: December 08, 2021, 02:44:14 am »
Here is some more info which may be of interest...
This is a very comprehensive video on a particular ADF4351 module and one thing it does is it explains how the Analog Devices eval board and software interact with each other:
[005] 4.4GHz RF Synthesizer Board - ADF4351 - Theory, Setup, Reverse Engineering, Experiments -- OpenTechLab
https://youtu.be/xJ0Mfuj0KUQ
By reverse engineering the eval board and software the author was able to write a python library to control any ADF4351 from a PC. You still need a way for the PC to send SPI commands to the ADF4351 and the python library has code which interfaces with a Bus Pirate USB device for this purpose.
The python library may be found here:
https://github.com/jhol/pyadf435x
The main thing this library has is the logic which figures out what the ADF4351 control register values should be to generate a particular output frequency.
Offline richard.cs
  • Electronics engineer from Southampton, UK.
    • Random stuff I've built (mostly non-electronic and fairly dated).
« Reply #3 on: December 09, 2021, 11:17:52 am »
I have used the official eval kit at work recently. It has a PIC on the board that pretends to be a USB-HID, and forwards raw register contents on to the synth. The protocol for this USB HID is entirely undocumented but fairly straightforward to reverse-engineer.
I suspect these cheap modules have a totally different interface.
