Author Topic: Distributed element filters/RF stuff solder mask  (Read 2965 times)
Offline darthtonyTopic starter
  • Country: gr
« on: March 12, 2016, 12:40:10 pm »
Why do distributed element filters, and generallly RF stuff on a PCB have some sort of gold plating and no solder mask on them? https://en.wikipedia.org/wiki/Distributed_element_filter
Offline jeremy
Re: Distributed element filters/RF stuff solder mask
« Reply #1 on: March 12, 2016, 01:19:26 pm »
I can only guess, but the soldermask will change the average dielectric constant of the region, and thus will affect the trace characteristic impedance at high frequencies.
From my quick googling, see:
http://www.icd.com.au/articles/Stackup_Planning_AN2011_2.pdf
http://www.sigcon.com/Pubs/edn/PassivationandSolderMask.htm
Perhaps it is more difficult to control the thickness of the soldermask layer than it is the shape of the traces.
  • Country: gr
« Reply #2 on: March 12, 2016, 03:29:28 pm »
That sounds reasonable, thanks!
Offline tggzzz
« Reply #3 on: March 12, 2016, 05:30:57 pm »
Firstly it will be lossy, which also translates into reduced Q in filters.
Secondly the material will be variable, and the thickness will be variable, which translates in to frequency deviations.
Offline nctnico
« Reply #4 on: March 12, 2016, 07:16:28 pm »
The soldermask isn't always left off. IMHO there is not much use in not having a solder mask because the etching tolerance will be as worse as the variation in the solder mask layer.
Offline KJDS
    • my website holding page
« Reply #5 on: March 12, 2016, 08:13:23 pm »
The only reason to lose it is loss. I've never measured any other difference.
Offline Dago
    • Electronics blog about whatever I happen to build!
« Reply #6 on: March 15, 2016, 06:15:28 am »
It increases loss and is not as controllable thus affecting the characteristics of the filter in a hard to predict way. At high GHz stuff it can also act as a waveguide and cause rather interesting problems.
Come and check my projects at http://www.dgkelectronics.com ! I also tweet as https://twitter.com/DGKelectronics
Offline LukeW
« Reply #7 on: March 17, 2016, 06:12:10 am »
In addition to the facts posted above, it looks cool :)
