Hi there!
I have been playing with the rf4463 1W G(FSK) 433Mhz module from nicerf recently. I am trying fetch/compute the RSSI after each rx packet. From the datasheet:
The RSSI value read by the API could be translated to dBm by the following linear equation:
RSSI (in dBm) = (RSSI_value /2) – RSSIcal
RSSIcal in the above formula depends on the matching network, modem settings, and external LNA gain (if
present). The RSSIcal value can be obtained by a simple calibration with a signal generator connected at the
antenna input. Without external LNA, the value of RSSIcal is around 130 ±30.
I don't have a signal generator, is there any way I can figure out that RSSIcal constant with another module?
lets say I connect two modules with a coax and use a 30dB attenuator, as well as setting the power to be max (1W). On the reciever I am testing, would the RSSIcal be:
RSSIcal = (RSSI_value / 2) - 36 + 30?
Thanks!
