yeah I thought about MAKING one with a micrometer last night!
And is it 24 AWG? I read that people say its 26 AWG for RG316 but I measure 24 AWG?! And the 26AWG smashed the first one. It broke the crimp in half on 26AWG setting.
The indenter (selector) settings for a given gauge are not the same for all contacts. It depends on the wall thickness of the contact, too.
What selector setting did you use?
Let’s figure out the AWG first:
The diameter of the inner conductor is 0.51mm, which matches 24AWG solid wire. But it’s stranded, and AWG for stranded is calculated by cross-sectional area, so go down one size, and you get 26AWG. But that’s a ballpark.
Technically speaking, the inner conductor is not specified as an AWG at all. The military standard that actually defines the construction (PDF attached) specifies 7 strands of silver-coated copper clad steel, each strand 0.0067” diameter. (0.0067” is halfway between 33 and 34AWG.)
If we calculate the cross-sectional area of each strand we get 0.000035 in
2. Multiply that times 7 and we get a total cross sectional area of 0.000245 in
2, which is just shy of 25AWG (0.000251 in
2).
With that said, since it is steel wire, not copper, I would probably err on the side of rounding up instead of down, for the purposes of crimping, especially in light of you having cracked a contact.
Now let’s find the selector setting:
As I said, the setting depends on wire size and contact design. A thick-wall contact needs a different setting than a thin-wall one. So we can’t blindly copy the settings from one positioner to other contacts.
Absent guidance from the manufacturer, the best we can do is try to find similar contacts and see what they use, then experiment.
The K13-1 positioner (which is really common, since it’s used for D-sub contacts) lists (now obsolete, standards unavailable) coaxial contacts, with RG316 listed in the supported cables. It suggests selector 4 for those.
I checked a few more positioners for RG316, and they used selector 4, 3, or 2. So as you can see, it really depends on the contact.
For what it’s worth, I crimped some similar BNC pins not too long ago and I’m pretty sure I used selector 4, maaaybe 3.
