Author Topic: How to use `nickel powder` and `lime powder` to paint `faraday cage`?  (Read 1246 times)
Offline youta556Topic starter
I try to build `faraday cage` room for RF testing,this job is for shield low frequency RF radiation.
I mix nickel powder,316 stanless steel powder and lime powder,add some water,that's my material of painting.
Before I start painting,I ask for advices here.Any formula of ingredients?Is that enough paint only one time?What will happen if I leave floor unpainted?Anything I should notice based on your experience?
Offline ahbushnell
What frequencies?
frequency band is 10hz-10Mhz.
Offline ahbushnell
What do you want to shield against?  Electric fields or magnetic?
 Electric fields.
Offline jonpaul
So called conductive paint has a relatively high resistance per square
A Faraday cage or screen room needs a copper screen with no gaps
Cost to buy or build a one man screen room is 10...100K$
what is your goal?
Jon
Jean-Paul  the Internet Dinosaur
Offline twospoons
Graphite paint would get you most of the way there, but if you really want to shield down to 10Hz you are going to need sheet metal. Sheet steel would be good enough, and a lot cheaper than copper.  You will need to seal all the seams with conductive foil tape.
And you need to do the floor too.
What are you doing for the door? Any electrical gaps when the door is closed will leak RF.
