Author Topic: HP 8753C amplifier measurements  (Read 1542 times)
Offline rfguy2020Topic starter
« on: December 08, 2023, 06:46:25 pm »
Hello,
I have HP 8753C (firmware 04.12) with 85044A test set. I have been using it mostly for antenna measurements (S11).
I'm trying to use it for amplifier measurement. I'm measuring Mini-circuits ZX60-V62+ as I can see values from data sheet. I have performed one-path 2-port calibration, since my test set does not allow full 2-port calibration. I have added 20dB attenuator to B port as maximum allowed power level is +20dBm.
S11 is really strange sometimes it is positive (>0dB), sometimes it is something I expected and sometimes it is between those two. S21 looks more or less expected, but it seems to go strange sometimes as well.
If I don't connect my amplifier to port B and just add termination to amplifier output, then my S11 is expected. So for some reason, S11 goes wild if I connect amplifier output to port B through 20dB attenuator. I don't understand how it detects that I have connected active device to port B? Is there something broken in my VNA or do I have to change some settings?
Re: HP 8753C amplifier measurements
« Reply #1 on: December 09, 2023, 08:06:30 am »
I figured out root cause by myself. I actually need to rotate the device for reverse and forward measurement as VNA instructs. For passive devices it does not make big difference if I don't follow this instruction, but amplifier or non reciprocal devices gives totally wrong results.
Offline DrNefario
« Reply #2 on: December 21, 2023, 03:07:40 pm »
An HP 85046A test set is the type that can automatically switch the ports around while making the measurements.
