Just got this 8753D with options 002, 006, 010, 1D5. The R CHANNEL jumper was sharply bent at one end but not shorted or open. The VNA powers up immediately to a working display with "NO IF FOUND: CHECK R INPUT LEVEL". Later I found that after I press PRESET it displays: INITIALIZING INSTRUMENT, PLEASE WAIT and then after a few seconds SELF TEST PASSED. Then I replaced the bent jumper with a 4" coax with no change visible. After a bit of reading I decided to try a Minimum R Channel Level Test from the service guide. The first try I got REFERENCE VALUE -70 dB and then TEST PORT POWER -55 dBm. I soon came to the conclusion that I had no idea of what I was doing so here I am looking for some guidance. I posted some pics on groups.io HP
Thanks
Hank
