Well I wound like 30 turns of fine wire, maybe more, around a 22nF axial foil capacitor, I think polystyrene (the clear one you can see the spiral through)
When hooked up to the meter it said 20nF at 1Mhz with 0.2 ohms and capacitance started reading negative around 8MHz
When I soldered the coil over it, at 1MHz it said 4nF + 10 ohms, and at 5MHz it read similar to the unmodified capacitor (the ohms dropped back down to 0.3 and capacitance rose), but today is not a day to write things down on a note pad and I don't remember the numbers. But that is like a notch of some kind right, since 4nF and 10 ohms conducts less then 20nF and 0.2 ohms and it looks like the textbook notch filter of LC parallel in series with a load, so by happen stance it looks like I made some kind of low frequency notch filter by winding 30awg kynar wire over a capacitor.
