Hello!
I wanted to build a simple PCB for a diode ring modulator to run some experiments on. The local oscillator input will be at max 455 Khz, while the RF input will be between 7.5 to 30 Mhz. I am matching the traces for a 50 Ohm impedance. I will be using JLCPCBs JLC7628 stackup. The signals for my layers are:
Top: RF
First: GND
Second: RF
Bottom: GND
I was hoping for some feedback for best RF practices on my layout. Questions I had:
1. How necessary is an RF Fence? I see this a lot in in other RF devices and they seem to be used as a Faraday cage of sorts.
2. Should I have my traces that are terminated by an SMA Connector exposed?
3. Is there a rule of thumb for spacing between the RF section say a via array that stitches the ground planes together?
I am new to RF PCB Layouts so any advice would be appreciated
