Author Topic: Interfacing MMIC prescaler to ECL (to replace an Agilent MMIC)  (Read 3522 times)
Offline fenugrecTopic starter
« on: February 23, 2024, 03:34:32 pm »
I'm in the process of replacing the notorious 1GC1-4210 prescaler (custom HP/A/K part) that has bricked countless ESG* signal generators and ESA44* spectrum analyzers such as the E4402B. Quick summary for those not familiar : the 1GC1-4210 divides the YIG signal (3-7GHz) by 1,2,4,8, or 16 inside a PLL loop, depending on 3 mode-select pins. On the spectrum analyzers, only the ratios 8 and 16 are used :
2031725-0
One viable repair strategy is a small (tiny !) pcb with two chained HMC862A dividers (1,2,4,8 ratios). I thought this was a bit wasteful (the HMC862A is quite expensive) since only 2 ratios are needed,  so after a bit of research I'm hoping one HMC862A wired to divide by 4 or 8, followed by an ECL divide-by-2 (MC100EP32), might work :
2031731-1
However I have doubts on the compatibility of the input/output structures (see datasheet extracts below) : the HMC862 has apparently a 50ohm output, probably similar to the original 1GC1-4210, and meant to be AC-coupled to the next stage; I'm not sure how well it would play if connected directly to the ECL divider ?
2031737-2
2031743-3
And (possibly more problematic), this ECL divider would end up driving the original AC-coupled attenuator, and I think this would probably require a 50R on both outputs ?
Really hoping I don't need ac-coupling and termination between the HMC and ECL divider, as this pcb is extremely tiny and needing 5-6 extra passives would make this solution much less attractive. I've attached a tentative layout to give an idea of scale - 9.2x6.3mm really doesn't leave much space at all :
2031749-4
« Last Edit: February 23, 2024, 03:40:26 pm by fenugrec »
Offline minsik
Re: Interfacing MMIC prescaler to ECL (to replace an Agilent MMIC)
« Reply #1 on: March 25, 2024, 07:06:17 am »
Why not https://www.leobodnar.com/shop/index.php?main_page=product_info&cPath=125_127&products_id=324&zenid=822d6aca34a60019cb77d6535385c9bc from Leo Bodnar. Professional built and supplied. Owning the precise GPS reference, which is the pinnacle of GPS frequency accuracy in my workshop I have no hesitation is suggesting this would be a way to go.
Minsik.
Years of working with electronics. Now its just for fun.
« Reply #2 on: March 26, 2024, 11:20:55 am »
Yes I am aware of the Leo Bodnar PCB, and it's great to have such a thing available "off the shelf". However it is expensive, as I mentioned partly due to the BOM cost. I was planning on maybe building a few, where it made more sense to build myself at a third of the cost.
Since I started this thread, I built a dual-HMC862A board (in the style of Bodnar's) to repair my ESA first, but now I'm not sure if I'm going to proceed with the simplified version, as I am not really equipped to validate RF performance of the mixed MMIC + ECL stage.
Planning on publishing more details of my build, including design files, in the near future.
The following users thanked this post: minsik
« Reply #3 on: April 16, 2024, 04:38:35 pm »
Finally got around to documenting this.
I opted for the more prudent 2x HMC862 option; I had the feeling that using the MC100EP32 for the second stage division was more of a risk and would require 4-5 more passives, making the PCB even more challenging.
I posted details and photos to https://www.qcte.ca/testeq/e440x_sa/
Additions and corrections welcome !
The following users thanked this post: edavid, minsik, Aiy, ch_scr
« Reply #4 on: May 05, 2024, 11:58:24 pm »
Finally got around to chopping up bits of video, https://youtu.be/SJsw54jveQs
Offline minsik
« Reply #5 on: May 07, 2024, 12:00:26 pm »
Good video and of course congratulations on the well done repair. Respect.
The following users thanked this post: fenugrec
