Sorry for not linking the datasheet, and thanks for the infos, but at this point I'm wondering if it's a #43 or a #77, although, given the frequency response of that UnUn I tend to believe that it may be more similar to a #43; thanks again (and no, I don't have a VNA, otherwise I won't be here asking for help
See, I'm going to help a friend putting up a random wire antenna, and I wanted a well working UnUn; since in a past I built this one https://vk6ysf.com/balun_9-1.htm but using an FT240-43 instead of the T200-2 which isn't good as a wideband transformer, I thought that the "V2" could be fine as the previous one (except for the core) was, that's why I asked about that L15 equivalence; but given the replies, I think I'll stick with an FT240-43 which already served well (the other randoms had SWR less than 1.5 on all bands from 80 to 10 meters and the radiation efficiency was confirmed by a lot of contacts made with 100W max)
Thank you again
Common generic ferrite split beads sometimes work really well for making ununs (or baluns) -they seem to be very good at this.
But you wind them differently, instead of going around it like you would a toroid you wind it through the middle, keeping the wire inside the cores as much as possible, the effect is you need fewer turns and shorter wire, I suspect this may be a very good way to do it, especially considering the cost. I'm sure it depends a lot on the material, but somebody might easily get lucky if it works well for RFI in a given frequency range there is a decent chance it might work well as a unun or balun. Can't beat the price.
Three wires twisted together makes a good 9:1 unun. Just a few inches of wire is needed. (Less turns than with a ring core)
You could also make a balun pretty easily. Try to use identical cores from the same batch. If you have four you could make a balun like the switchable elecraft balun (BL-2) which can do both 1:1 and 4:1 by switching the output from series to parallel
You'd ideally use four identical cores, and you need a DPDT switch. Make with two binocular cores that balun is really efficient. It can be grounded in the middle. Take care to make it symmetrical.
But even if you just have a single split core you can make a decent working unun, wrap three wires together in a twisted pair like way. If you are using ethernet wire I wouldn't try to wrap it super tight unless you are using thicker wire. Slightly less tight but neat. I did it with two cores and that works quite well. Its just soldered to a BNC female connector and it currently has two alligator clips to connect to antenna and ground.
