Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
RF, Microwave, Ham Radio
Question about making 433MHz antenna
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Question about making 433MHz antenna (Read 2375 times)
amwales
Regular Contributor
Country:
on:
February 09, 2016, 09:06:14 pm »
I want to make a 1/4 wave 433MHz antenna. Should I be concerned about the type of wire I use.
I understand that it needs to be 173mm long but is it ok to use silicone insulated stranded copper wire?
Logged
davebb
Regular Contributor
Country:
Re: Question about making 433MHz antenna
Reply #1 on:
February 10, 2016, 12:59:04 am »
Hi yes that will be fine, use the thickest wire will give you the best band width, but at 433mhz it will be wide ,don't forget your counter-poise/ground is half of your antenna, if I was you I would make a halfwave ant and get some gain.
Dave 2E0DMB
Logged
GreyWoolfe
Supporter
Country:
NW0LF
Reply #2 on:
February 10, 2016, 01:14:28 pm »
To add to that, you want to think about which type of antenna will work better for your application-an omnidirectional or a beam antenna. The beam will give you gain at the expense of front to back and side to side rejection. Otherwise, Dave is on the mark with a 1/2 wave or better to get gain. Gain is good!
Tom, NW0LF
Logged
Z80
Guest
Reply #3 on:
February 11, 2016, 02:37:18 pm »
To answer your question about making a 1/4 wave, the type of conductor you use doesn't matter. One point to note though is that the length you quoted 173mm is the free space wavelength. It will be slightly shorter in a piece of copper wire, more like 168 / 170mm. if you are using it for a receiver then it won't really make much difference, but if using it for a transmitter you will need to trim it to resonance either by using an SWR measurement or by trimming for maximum radiated signal. The ground system you use and the environment will also affect the length slightly.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
