At 500 MHz, anything active is going to be a PITA. Feed a reversed Bias T with a DC source to offset its output. Making the DC source track the peak amplitude will be a PITA, and a PITA2 if the signal is AM modulated, so if you can live with a manually set DC offset, don't try to make it tracking!
