Namely the end metallization is wraparound, so it gets a nice big chunk (relatively speaking) of parallel capacitance from the Al2O3 body; the special ones are a "flip chip" style I think, solder pads (DFN style) and element on the same side. Field divides through thickness and length of the substrate, capacitance is lower.
Adjusting substrate thickness, and possibly material (thus, K), are other variables they might play with. No idea if anything other than Al2O3 is ever used, actually.
Have seen a few precision resistors in the style, but being 0.1% or better, the cost might not be what you're looking for, anyway.
Other tricks can be played, like ground relief under the pads or body. You really need a simulation model to do stuff like that, and if you're asking about specialty resistors at these frequencies in the first place, you really need those tools regardless.
