I received the Mini-Circuits ZBSF-95-N+ filter today. I've run it on a different VNA this time and overlayed the RTL-SDR filter results
Mini-Circuits in Green
RTL-SDR in Blue
I'm a bit underwhelmed with the performance of the Mini-Circuits filter, especially considering it's cost over over the RTL-SDR filter. It's attenuation in the broadcast band isn't as good, although it does have less insertion loss and less attenuation at the start of the airband.
Unless you want to listen to the lower end of the airband I'd have to say the RTL-SDR filter is the best bet, certainly best bang per buck
