Hey Uky,
Don't want to dissuade you from using these forums but man, out of the 13 pages of the datasheet 3 whole pages detail 50Ohm operation, including specs, plots and even recommended tuning component values.
Also your mindset is incorrect about asking Macom. Be bold, go bug them! (I mean this in a positive, encouraging way.) If they have the data they will send it to you regardless if you bought none, 1 or 10,000. It doesn't cost them anything. If they don't have the data they would not take it for you unless you buy a million, there is not really a middle ground of you have to be an established professional.
Good luck!
