Author Topic: Measurement of Radar Cross Section using a VNA  (Read 2186 times)
Offline BudTopic starter
« on: February 03, 2017, 05:01:15 am »
For you Radar aficionados, an interesting Application Note from Anritsu on using a microwave VNA to measure radar cross section parameter of objects:
https://dl.cdn-anritsu.com/en-us/test-measurement/files/Application-Notes/Application-Note/11410-00604B.pdf
The link from the VNA to the object and back is represented by an equivalent 2-port network and a formula is derived to calculate the radar cross section from VNA S21 measurements. A metal sphere with a known cross section is used as a reference standard. Also time gating feature of the VNA is used to cut off clutter. It is fun to read the article if you understand VNAs and a little bit of Radar.  :-+
Offline LaserSteve
Re: Measurement of Radar Cross Section using a VNA
« Reply #1 on: February 03, 2017, 10:12:10 pm »
That is just ever so Cool, Thanks!  Something to try this weekend.. !   :-DMM
Steve
« Last Edit: February 03, 2017, 10:14:27 pm by LaserSteve »
"Analog and Loving It"
Online KE5FX
    • KE5FX.COM
« Reply #2 on: February 03, 2017, 11:42:41 pm »
Don't forget HP's original take on the subject: AN 8510-2.
« Reply #3 on: February 04, 2017, 06:13:58 pm »
Very nice, thank you!
