Author Topic: RF Explorer ghost signal  (Read 1712 times)
Offline BosonTopic starter
  • Country: sk
« on: February 03, 2017, 02:03:45 pm »
Bought RF Explorer 6G combo, investigating. First think 4900-5100MHz flooded with RF but then disconnect antenna and walk around. Houston we have a problem! Is this normal and present on every RFE  :-\ Device brand new - no abuse.
Offline arocholl
Re: RF Explorer ghost signal
« Reply #1 on: February 05, 2017, 12:32:26 pm »
Hi, this is actually a known limitation in the low band noise floor adjustment.
The factory calibration process ensure the power reading is accurate for all range, and therefore some noise floor discontinuity happens, this is normal in all spectrum analyzers of all brands, although in this case we recognize is higher value than ideally expected.
We are working in a new firmware to be available shortly which will flat the noise floor significantly and still keep calibrated amplitude reading wideband.
Cheers
RF Explorer Team
The following users thanked this post: Boson
