Author Topic: Mechanical 3D filter realization from coupling matrix  (Read 258 times)
Offline jujun
« on: April 23, 2019, 02:56:44 pm »
Hello,
I feel the need to know more about microwave filter that are made of coaxial
cavity cell that are coupled, and sometime with a topolgies like "cascaded tuplet" or "cul de sac".
It seems that this kid of filter that is everywhere (like in mobile phone base station) is first made with a software that generate a coupling matrix. (ex : http://www.gwtsoft.com/ ) And then this coupling matrix is used to make the mechanical filter.
But everything I read about it is kind of magical, because there is nothing about how it is done.
For exemple here : https://www.cst.com/solutions/article/filter-design-technology-2017
There is nothing about the mechanical part, it's "magical".
So I guess that you have to model one 3D cell and then build your filter by cascading them ? But how to use the coupling matrix to automate it ? It must be a quick way to do it.
Any pointers on how to do it ?
Any pdf about it ? or book ?
Is there any software that will do the work ?
Thank you
« Last Edit: April 24, 2019, 09:25:34 am by jujun »
Offline rfeecs
Re: Mechanical 3D filter realization from coupling matrix
« Reply #1 on: April 23, 2019, 11:42:31 pm »
Here's one pdf from the website you referenced.  The whole process is gone through, including determining mechanical dimensions:
http://www.gwtsoft.com/Misc/Hagensen3.pdf
The following users thanked this post: Mechatrommer, jujun
