Hi all.
I am designing a little personal project using an RN2483. Im based in Europe so I dont need (cant use) the 433MHz antenna.
What should I do with that antenna port if I am not going to use it? Im no RF expert, but I believe it should be terminated if not used or connected to an antenna. Should I "simply route it through a 50ohm resistor to ground"?
Thanks!
