I'm looking for suggestion(s) as to how I can mitigate unwanted RF from a nearby AM broadcast station that may be arriving common-mode style and adversely impacting operation of my (HF/ham radio homebrew) receiver. Based on some observations (below), I think the AM broadcast signal is taking a common-mode path from antenna/wiring to the receiver where it's detected regardless of which frequency the receiver is tuned to.
The receiver is a homebrew version of the "usdx" simple microcontroller-as-DSP HF receiver, which at it's core is basically a direct conversion, phasing detector design followed by gain stages. All (all) of the receiver's gain follows the "tayloe" detector, a 60 dB op amp stage followed by process gain in the embedded DSP code.
There is a nearby, high power AM broadcast station at 1690 kHz - about 2 miles from home. It produces measurable voltage at the port of my lowest-band, longest-wire antenna during daytime, so it is very strong energy source.
The receiver appears to be detecting the AM signal regardless of tuned frequency (as if the 60 dB gain stage is simply operating on rectified audio from the AM broadcast station, along with the (sometimes weaker, sometimes stronger) intended signals coming from the Tayloe detector and associated quadrature clock.
A sharp high-pass cut-off filter (about 2 MHz corner) in the antenna-to-radio (coax feedline) path significantly reduces artifacts from the AM BC station on other (conventional superhet) receivers here, but this receiver is unaffected by presence/absence of the high pass filter (however, if I disconnect coax from the filter to the receiver, the AM detected audio, as well as any intended signals, disappear.)
I think the culprit may be common mode path conducting 1690 kHz into the receiver's circuitry, as the radio is acting like a crystal set (the AM station's detected audio level is unaffected by any of the RF circuitry - mainly RF filters and associated switching - in the receiver.
Would a RF transformer (i.e., two windings sharing a common powdered iron or ferrite core) interrupt a common mode path? Is there any systematic way of identifying the path this 1690 kHz AM signal is taking to get into the receiver?
Thanks for any pointers, suggestions, or requests for clarification/improvement to my question.
