I have a NanoVNA that´s laying since quite a long time in the drawer and that was so far mainly used to measure the length of coax-cables.
Currently I´m playing with micro-coax cables and I´m trying to figure out if e.g. SMA-crimp connections are good or bad. It seems like the reflection measurement is most sensitive to impedance mismatches, so I´m starting to get a calibration that is as good as possible.
Can anyone tell me if the following spectra show something generally wrong?
That´s the 50
load directly after calibration
That´s the 50
load just after opening it up and re-attaching to the SMA-socket:
In best case both images would be identical - but are a) SMA connections just generally that unreproducible, are b) RF-connections just that sensitive that these variations are normal or is c) something wrong with my VNA or with the calibration kit?
I´m using a NanoVNA V2 clone. I have three 50
-calibration loads and this one is the most stable of all three.
