Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
RF, Microwave, Ham Radio
Must Ground Plane Connect Directly Under Antenna?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Must Ground Plane Connect Directly Under Antenna? (Read 729 times)
johnywhy
Contributor
Country:
on:
December 09, 2024, 09:10:29 pm »
In this proximity coupled antenna, is it necessary to solder a ground connection directly beneath the antenna? Or can the ground plane be connected to ground point elsewhere on the ground plane, far away from the antenna?
Assume the patch substrate and ground plane are several wavelengths larger than the patch.
Last Edit: December 09, 2024, 09:51:04 pm by johnywhy
Logged
szoftveres
Regular Contributor
Country:
Re: Must Ground Plane Connect Directly Under Antenna?
Reply #1 on:
December 10, 2024, 01:59:06 am »
If I were to feed this antenna with e.g. a coax line, I'd solder its outer shield to the ground plane right where the stripline starts at the edge of the substrate..
Logged
johnywhy
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
