Author Topic: NanoVNA Custom Software  (Read 190867 times)
DiSlord and 2 Guests are viewing this topic.
Offline joeqsmith
Re: NanoVNA Custom Software
« Reply #1200 on: July 11, 2021, 02:43:41 pm »
Good morning Mr. Smith,
Thank you for the reply and comments!
Thanks for hanging in there.
I suspect you don't always look at the attachments which leads to some of your confusion.
Mr. Smith, in other software it is not stipulated directly, but it can be seen from their use. As an example, NanoVNA-Saver or VNWA-3 software. When you calibrate the device, the sweep is turned on automatically only when the calibration standards are applied and when the user presses the corresponding buttons. After completing the calibration operations, the sweep is inactive and can be turned on by the user when needed.
I looked at one of the very first open sourced programs when they had just started to develop it to make sure it connected and provide that feedback.  Outside of that, I've only looked at the software supplied with the low cost VNAs.   I wrote the original software 20 some years ago and continue to develop it.  I show the software from 2002 working with my first VNA and a home made converter.
https://www.eevblog.com/forum/testgear/agilent-e835xa-pna-vna-notes/msg3604844/#msg3604844
Outside of using an 8753, at that time I had no other experience with VNAs or their UI.
Mr. Smith, again - it is clear that you designed the software first for your personal use (maybe some friends) and probably without the intention of giving it in that form to others. Therefore, its use is less intuitive.
In the case of the series products, most manufacturers have implemented similar functions and modes of operation, to reduce the learning curve and to ensure that the potential buyer (user) will not be discouraged.
I try to discourage people from using my software.  It's free.   Support, well if you you can't do your own research or even be bothered to review the materials provided, expect to be called out.  While user's (especially the amateur radio group) view themselves as customers, I don't.  This is my business model.   :-DD     If you can make use of it, fine.
I already understood you, it remains to be seen how you will want to treat what you started, if you want to help amateurs with items from the pro area and if observations such as those made by me can cause you to add details to the user manual which you may not have thought of.
Obviously, it's up to you first  :)
The majority of amateur radio operators who have contacted me have made it clear that they are entitled, demanding, like to whine and their license makes them an expert.  It's a really an odd trend and not what I would have expected.  I have no interest in working with such people at any level.
And also, although you posted pictures in the manual, the fact that you have to use ChnRef ON to calibrate and OFF after that, is less visible (although you are right that you wrote about it).
Odd that you are still not understanding the Chn-Ref.   You would never set Chn-Ref ON before running a SOLT.  Of course, the software will allow it and assumes you know what you are doing.   With so many videos walking you through the basics and my continuing to point out you're not understanding it, I am surprised.
Believe me, I also turned to a friend with experience in the field, who did not "catch" the trick of using your software, even after 15 minutes of remote session on my PC.
It's like switching from HP/Anritsu to R&S.  8)
With you showing them the ropes, it doesn't surprise me at all.
Later, you can also do something else, if you like: extra paid support. You can get an advanced edition of the manual, which includes more examples and detailed explanations, for a fee. If it has an affordable price, people will definitely buy it.
You have no idea of the time and effort I have put into testing handheld DMMs.  Sure the meters cost money as well but that's hardly worth mentioning.  I have never asked people to join my non-existent  Patrion, click that bell, subscribe and like, and ads are disabled.  Outside of the EEVBLOG, I have no social media presence, no twittbook accounts.  I have never asked anything from my followers other than not to whine.   If people get something out of what I post great.  Don't like the content, find a better channel.  I work on what I want, when I want and once in a while share it.
Regarding normalization, if it has the same meaning as the one I used for the old HP8714B, then you may have already understood ;-)
There, the procedure has been named "Normalization Calibration".
The analyzer stores measured data taken ( DUT not connected) into memory, and divides subsequent measured data by the stored data in order to remove frequency response errors. On that device, the normalization calibration could be used either for transmission or for a reflection measurement. At the end of the procedure, the DUT is inserted and when starting sweep, the data displayed is the transmission coefficient for the DUT (including all the connectors and cables) divided by the transmission coefficient for the connectors and cables alone.
So, do you think that in the case of your software, the normalization process does the same thing?
My first VNA was all mechanical.  The storage normalizer was an add-on and allows subtracting the reference (and a few other tricks).  There was no means to run a SOLT calibration.  Or course, add a PC with some software and that can be resolved.  Of course, normalize still has its place and why I continue to support it.
Believe me I know and understand this aspect. I am also an engineer, but not in the RF field.
On this forum, Dave has made it clear that everyone is an engineer who wants to call themselves such.   So, sure.  When I talk about engineers in the context of my software, I am assuming they hold a BS or MS in EE.   Again, I'm not suggesting that it is required but that is the target audience (of one).
Cleanup.
Also, thinking about paid support.   A friend of mine had brought me a product they had bought used and asked if I could check it out.   It worked really well and I was so impressed with the design I got in touch with the company who produced it as it was no longer being offered.  I spoke with sales as well as the designer explaining how impressed I was and how I was so surprised they stopped selling it.
What had happened is they made a very nice product and sold it to a market that had no clue how to use it.  They were so swamped with trying to answer the basic questions (IMO it had a well written manual) that they could not focus other parts of the business.  So they dropped it.
« Last Edit: July 11, 2021, 02:56:11 pm by joeqsmith »
How electrically robust is your meter?? https://www.youtube.com/channel/UCsK99WXk9VhcghnAauTBsbg
Software, documentation and test reports for the low cost NanoVNA & V2 Plus 4 may be found here:
https://github.com/joeqsmith
Offline joeqsmith
« Reply #1201 on: July 27, 2021, 03:08:31 am »
I've been looking back into the lockup problems that caused me to pack up the V2Plus.   Enough time had passed I wanted to see if the new firmware addressed the problem.  Attached picture is showing the version I am currently testing (nothing more than staying connected and collecting data).   If this version will stay running for 24 hours non-stop, I will have a look to see if has any problems that would prevent it's use with my software.
https://groups.io/g/NanoVNAV2/topic/84446397?p=Created,,,20,2,0,0::recentpostdate/sticky,,,20,2,0,84446397
I wonder if the people writing the firmware are even aware that they addressed the lockup problem or if they just got lucky.   :-DD    If you enjoy endlessly reprogramming your devices and wasting time hunting problems like this one,  I highly recommend these low cost VNAs.   Endless fun. :-DD :palm:
missing words...
« Last Edit: July 27, 2021, 10:42:16 am by joeqsmith »
Offline Alextsu
  • Country: ru
« Reply #1202 on: July 27, 2021, 06:17:30 am »
Hi, Joe,
There is now an alternative FW for all V2-2 versions, ported from NanoVNA by Dislord,
check this link
https://groups.io/g/nanovna-users/topic/84427595
Though haven't tried it yet
Offline joeqsmith
« Reply #1203 on: July 27, 2021, 10:57:20 am »
Hi, Joe,
check this link
I had spent a fair bit of time trying some of their firmware on an H4 I had purchased recently.  I would have no reason to try their firmware on other devices.   If you are interested in reading more about that testing:
https://www.eevblog.com/forum/rf-microwave/nanovna-custom-software/msg3579600/#msg3579600
The V2Plus has ran for 24 hours using various settings without a single lockup.   :-+  It's never been this stable.   Next step is to see if it will put out some good numbers.
If you don't have access to the groups.io because of their dick move to lock it, use the mirrored site:
https://nanorfe.com/forum/V2-Plus-Firmware.html
The following users thanked this post: TheDane
Offline JohnG
« Reply #1204 on: July 28, 2021, 05:45:30 pm »
Thanks for the software and the excellent documentation. I have had no trouble following the instructions and getting the software up and running with my NanoVNA V2Plus4.
I do have one difficulty, which has to do with readability. On my Win 10 computer with 1600 x 1200 monitor, the software window is small and hard to read. After playing with many settings,  the only workaround I can find is to change the monitor resolution to 1280 x 800, which helps some, but messes up my Windows desktop (rearranges the icons), and adds a little blur to the display.
Do you know if this is a fundamental limitation of the National Instruments platform used to develop the software? If so, I can at least quit fiddling with it.
Thanks,
John
"Those who learn the lessons of history are doomed to know when they are repeating the mistakes of the past." Putt's Law of History
Offline joeqsmith
« Reply #1205 on: July 28, 2021, 09:17:30 pm »
Thanks,
John
Who knows what you were expecting.  Maybe you expect the graphs to scale.  Obviously the font sizes are fixed.   There are videos on YT about designing software with LabView using the autoscaling if you are interested in learning about it.
I've run my VNA software on 1280X1024 19", 1920X1080 27" and 1920X1200 24" and its very easy for me to read on them all.   It is designed to run on my laptop which has a 17" display.
You should consider running  one of the popular open source programs.  If you really have some need to run my software and your choice of monitors was poor for your eyesight,  just buy a new monitor.  They are cheap.
Offline neilhao
    • My Personal Website
« Reply #1206 on: July 28, 2021, 09:39:44 pm »
I just gave this firmware a shot. Generally, it is amazing with more features, however it still has bugs for now.
I noticed this firmware could not measure the correct results in low freq band on the V2_2 hardware, e.g. from 50kHz to 100kHz. The official firmware has no problem.
Hi, Joe,
check this link
Notes about my technological project: https://uniteng.com
Online DiSlord
  • Country: ru
« Reply #1207 on: July 29, 2021, 07:19:42 am »
This can related to output power for SI5351 (i add option for select it, See STIMULUS->CFG SWEEP->TX POWER, for low freq range need select minimum SI -10dB), i add fix for this in next.
PS also in this fw real frequency step in < 140 MHz range = 1Hz
The following users thanked this post: neilhao
Offline JohnG
« Reply #1208 on: July 29, 2021, 03:40:19 pm »
It appears the display resolution of the software interface is fixed. That's the answer I was looking for, and I have no further expectations because it is free.
John
Offline joeqsmith
« Reply #1209 on: July 29, 2021, 08:29:42 pm »
John
Again, I'm not sure how you expected it to work.  Most software I use will not scale the fonts.  It could be done  (selecting a different font for example) but it's uncommon.  LabView will allow most graphics to be scaled.   Currently the software uses graphs that were manually drawn using a CAD program and saved off as raster images.   If I settled on the standard graphics, these could easily be scaled but I wanted my own graphics.
Buying a monitor that is easy for you to read would seem like a must, just for your normal use.
Windows 10 does have that magnifier built into it.  Really a poor solution IMO, but it's there.
« Last Edit: July 29, 2021, 08:48:28 pm by joeqsmith »
Offline joeqsmith
« Reply #1210 on: July 31, 2021, 07:19:33 pm »
I finally had some time to put a short video together showing flippers printed torque wrenches.
Offline ALW
« Reply #1211 on: August 05, 2021, 08:50:26 am »
Thanks a lot JoeSmith for this excellent SW. I am learning to use it... Available options are massive, but I believe it is very powerful.
As for the readability issue on high density screens, I think I found a solution in Win10 that works nicely.
In C:\Program Files (x86)\NanoVNA_V2Plus right-click the .exe, select "properties" tab "compatibility"
Click "Change high DPI settings"
Select "High DPI scaling override" option "System (enhanced)"
In my case that made the display crisp and clear and very well readable. Only drawback is that some vertically rotated graph legends were cut off, but I can imagine what they say.
Best
Al
Offline joeqsmith
« Reply #1212 on: August 05, 2021, 12:14:11 pm »
John was having problems with a 1600 x 1200 monitor.   I have used it on monitors up to  1920X1200 24" with no problems.   John fails to provide details about the size the monitor they are using.   If my crystal ball would ever get repaired then maybe I could see it was an 4" LCD.
I would expect with the display and keyboard being most peoples primary interface to the PC, that you buy something that fits you.  Especially if you use the computer often.   There are 1600X1200 17" monitors fairly cheap but with my ageing eyesight, at that ratio I would have no use for one.
Offline ALW
« Reply #1213 on: August 05, 2021, 03:46:47 pm »
Forgot to mention that I am using a Surface with 2160x1440 resolution. The unmodified / standard magnified window was blurry and difficult to read. With the settings above it is crisp and clean.
BR
Offline joeqsmith
« Reply #1214 on: August 05, 2021, 03:55:15 pm »
BR
12" display?   Do you have the docking station with a separate monitor?
Offline ALW
« Reply #1215 on: August 05, 2021, 04:28:44 pm »
10" display, no docking
Offline joeqsmith
« Reply #1216 on: August 05, 2021, 04:39:38 pm »
Wow!!  No wonder you were having problems viewing it.   Maybe John was attempting to run it on a small tablet as well.
Offline ALW
« Reply #1217 on: August 09, 2021, 02:55:08 pm »
@joeqsmith thanks again for sharing this incredible piece of SW. I still can't believe I am using a little cheap box with this professional interface.
I am trying to analyze the recorded sweep data in Igorpro for prototyping a medical radar application (trying to visualize heartbeat / breathing by analyzing the phase of the signal reflected by the body surface).
If you find the time, could you provide some short hint how the binary sweep data are structured in the recorded sweep file? Little / big endian, byte index, port1 port2 interleave,...
Thanks a lot in advance, best regards
Albrecht
Offline joeqsmith
« Reply #1218 on: August 09, 2021, 03:42:11 pm »
Someone else asked a similar question.   If you know what format you need, document it.  Make sure you include every detail.  It can be ASCII or anything else you want.
Offline ALW
« Reply #1219 on: August 09, 2021, 03:58:20 pm »
What I need would be similar to a touchstone s2p file:
Columns
Freq Re{S11}  Im{S11}  Re{S21}  Im{S21}
or alternatively
Freq MagS11 PhS11 MagS21 PhS21
Lines
Freq1
Freq2
Freq1
Freq2
for continuous sweeps
If it is ASCII or binary doesn't matter, I could read both as long as I know the header / offset and byte structure of the binary.
Offline joeqsmith
« Reply #1220 on: August 09, 2021, 04:23:53 pm »
Which software are you are using?  I may add it to the main program is why I ask.
Let's assume ASCII, do you want the frequency in Hz?  SI units?  What?    Same for Mag in dB and phase in degrees?
Are you wanting to use a SPACE, 0x20 for the delimiter as shown?
How do you want to mark the end of line?  CR?  CRLF?  LF?
Also, I don't understand the Freq1 showing up twice in your example.
« Last Edit: August 09, 2021, 04:26:30 pm by joeqsmith »
Offline ALW
« Reply #1221 on: August 09, 2021, 04:41:07 pm »
First, thanks a lot for your help! I really appreciate it.
I am using a software called IgorPro, that I am familiar with. It is similar to Mathlab, but is more powerful in doing complex math in (almost) real time, therefore cool for prototyping, later I am planning to retrieve the data directly using the com port of the Nanovna. Igor can read any data structure as long as I can tell it the structure.
So for your questions, anything that is most convenient for you when programming. Freq in Hz Mag in dB and phase in ° would be fine. It is however no problem to convert from other units if this would save your time. Space as delimiter and CR EOL would be fine too. Or if binary the byte structure of the float and the indexing / header length would be all that is required to read it.
With the freq1 showing twice (looping) I mean the recording should loop through the frequencies for multiple repeated sweeps... Of course it would be enough to have the frequencies only once, they do not need to be repeated
« Last Edit: August 09, 2021, 04:59:15 pm by ALW »
Offline joeqsmith
« Reply #1222 on: August 09, 2021, 04:56:38 pm »
When I asked
  I am referring to my software.  I would have no way to add anything to IgorPro.   No matter as it sounds like you shouldn't have any problems then working with the binary file directly.
FREQ (double)
CHANNEL0&1 (double complex)
The data is contiguous.
Offline ALW
« Reply #1223 on: August 09, 2021, 05:10:09 pm »
Sorry, I misunderstood you. Using your latest release r2.0.3 with a NanoV2+4.
Should be able to read your binary, but do not understand yet. Your bin file seems to have a header, do you know how long that is / where the data block starts?
FREQ (double)
means
FREQ (double)
CHANNEL0(double complex)
CHANNEL1(double complex)
I am reading the Labview specs right now, I think I am finding the definitions. Looks like double complex is 64bit real 64bit imaginary. Will try to figure it out, thanks a lot!
edit: With the freqs being repeated I should be able to find the data block/ header end. Will bug you only again if I can't figure it out
« Last Edit: August 09, 2021, 05:19:42 pm by ALW »
Offline joeqsmith
« Reply #1224 on: August 09, 2021, 05:29:57 pm »
Yes, channe0 followed by channel 1.  Yes, double is 64-bit.  Yes complex will store both the real and imaginary component to two separate 64-bit numbers.    The header is from prepending the array size.  Data is stored big-endian.
