The new release of Solver will not be compatible with the earlier releases and requires a new Defaults file to be created. This is why the major revision number was incremented. Shown is a decoupage of the main changes involving the UI. Note that it supports several databased standard setups. Like the polynomial coefficients, the file locations for your databased standards are stored into the Defaults file. For those of you using a transfer relay with Solver, note it supports unique Touchstone files for each port. So if you are testing an insert able device, you would calibrate the two ports using your male and female standards. If you wanted to use the same sex, single set, just select the same Touchstone files for both ports.
I believe we have already discussed the other changes.
Solver's TDR/TDC math still differs from how CMT and METAS handle the reference plane, for now. Again, I am not apposed to changing Solver if I ever get it through my head why what they are doing makes sense. My skulls thick so it may not happen.
I have had people approach me about doing some sort of collaboration in the past. Typically I ask them about their experience with LabView, education level..... That normally ends the discussion. I assume they just wanted the source for their own personal gains. I am thinking about releasing a VI wrapper for the TDR function and let people post their own source code for it. If some bright young LabView guru came up with something that we could all agree on, I could just add it in. Maybe allow the user to select the method.
6.00, 10/25/2024
Update readouts when loading S2P files
Combine stability trigger to other cursor handler, all cursors now track
Change 2-Port Adv. Plots to SI units
Change TDR/TDT impulse curves to use the amplitude scale
Swap TDR/TDT samples/seconds graph axis selection
Expose all TDR/TDT filter settings to user
Add support for METAS time domain modes using an uneven step size
Change TDR FIR filter to Zero Phase IIR filter
Add 2PSwp to readout event
Add Reflection types of round trip and one way
Force the EXE location as a starting directory for Defaults and other files
Add full 2-port support for databased standards SOLT
Allow multiple sets of databased standards
Allow saving Databased standard's paths to the Defaults file
