Author Topic: NanoVNA Custom Software  (Read 465636 times)
Offline radiolistener
  • Country: ua
Re: NanoVNA Custom Software
« Reply #125 on: August 20, 2019, 06:22:39 pm »
According to application icon this is .net.  :)
https://github.com/erikkaashoek/Tapr-VNA
« Last Edit: August 20, 2019, 06:26:11 pm by radiolistener »
Offline erikka
« Reply #126 on: August 20, 2019, 06:42:27 pm »
Yes. PC software to control hw similar to nanovna
Offline joeqsmithTopic starter
« Reply #127 on: August 20, 2019, 07:27:19 pm »
Is your plan to port it to the NanoVNA?
Offline wwoofbum
« Reply #128 on: August 20, 2019, 10:28:06 pm »
The nanoVNA appears to be based on a kit, the Vector Impedance Analyzer, produced by the Austin QRP Club.  The website on which this kit was available (currently sold out), https://www.qsl.net/k5bcq/Kits/Kits.html, has considerable documentation which might be of use.
Just because you can, doesn't mean you should.
« Reply #129 on: August 20, 2019, 11:24:15 pm »
I tried running a narrow band sweep, set to 909 data points rather than 101.  The standard deviation is still not real good.
« Reply #130 on: August 20, 2019, 11:28:03 pm »
Cleaned all the connectors, torqued everything then repeated the test with the same settings.  It had a fairly dramatic effect.
Offline gardner
« Reply #131 on: August 21, 2019, 05:03:41 am »
You had an extra comma in the URL which caused it to totally fail.  It took me a few mins to figure it out since the main page has no links to this stuff.
--- Gardner
Offline erikka
« Reply #132 on: August 21, 2019, 07:07:26 am »
No, as I do not own a nanoVNA, but its sub 50$ price makes it tempting.
All HW dependencies in my SW are in the USB_EZ_interface files. Main part is setting the VNA do to a scan (the "Sweep" function)  and retrieving the data (the "ReadWrite" function), just like the nanoVNA commands
« Reply #133 on: August 21, 2019, 12:27:40 pm »
Maybe someone else will port it over.  It looks like it would be a decent interface as is, or as a minimum a good start to one.   Actually, what they have for the Nano wouldn't be too bad if they would fix the readout.
A while ago, I was playing with a TI 32-bit ADC and put this box together for it.   The plan is to run a longer narrow sweep (same setup as the last test) from a cold start with the nano in this box.
SP
« Last Edit: August 21, 2019, 06:42:55 pm by joeqsmith »
Offline erikka
« Reply #134 on: August 21, 2019, 03:16:38 pm »
The NanoVNA is rather immune to EMC as the DSP IQ demodulator is only sensitive to one very narrow frequency (couple of Hz around the measurement frequency). However when scanning the complete range you may run into spurs from the CPU or SI5351 clock right at the measurement frequency and that translates to impedance deviations
I added a "spectrum analyzer" in my own SW where I disabled the test signal output of the SI5351 and only run the demodulator LO and measure the power present on the selected frequencies. You have to modify the measurement SW in the VNA for this as there is no longer a reference signal to compare to.
This spectrum analyzer mode will quickly show if there are relevant spurs interfering with the impedance measurement. And its useful as a (rather bad) spectrum analyzer
« Reply #135 on: August 21, 2019, 05:37:38 pm »
Plots representing over 5 hours of data, using the same settings.  Unit was calibrated while inside the case, everything torqued.  It appears there could be some gains to letting it warm up for a little while.   Standard deviation is just under half.
All of this data was taken using the Nano's internal calibration.
« Reply #136 on: August 21, 2019, 05:46:49 pm »
If we only look at the 4 - 150MHz region, basically removing the two ends were it starts to have trouble, the noise is much closer to a gaussian distribution and the standard deviation is 5x lower.   I may try repeating this test using my own calibration routines and see if I can flatten it out.
Offline tkamiya
« Reply #137 on: August 21, 2019, 06:28:04 pm »
I am very impressed!   :-+
The following users thanked this post: joeqsmith
« Reply #138 on: August 21, 2019, 07:02:46 pm »
The mechanical relay and some new end launch connectors just arrived for the second attempt at a transfer relay for the Nano.  The plan is to keep the case size the same.  Maybe this one will work good enough to show.
  • Country: ua
« Reply #139 on: August 21, 2019, 07:18:29 pm »
« Reply #140 on: August 21, 2019, 08:16:35 pm »
Do you talking about these 600+ USD mechanical relay?
https://www.pasternack.com/sma-electromechanical-transfer-switch-18ghz-35watts-24-32volts-f-pe7150-p.aspx
From the datasheet:
Length 2.63 in [66.8 mm]
Width/Diameter 2.16 in [54.86 mm]
Height 1.36 in [34.54 m
Looks like it may not fit.    :-DD :-DD   That said, the Mini-circuits part I linked was half the price.  Both would get the job done.
As I mentioned, I have an old transfer relay that I could easily drop in and use but my goal wasn't to just show an old relay connected to the Nano like the video I had linked.  That video doesn't show anything about how it is actually used and I doubt many people would want to see me just connect a relay.   I would like to sort out something cost effective that could be replicated.
That cost effective part is up in the air.  $600+, seems a bit excessive.   :-DD
Offline ealex
« Reply #141 on: August 22, 2019, 07:47:08 am »
@joeqsmith - nice thread
my unit just got here - I've only had time to take it apart ( i's missing the RF section shields ) and run some basic checks
I'll look over the python interface for linux, but the next weeks will be overloaded.
(an idea - make it as an attachment for a RPI3 + LCD -> make a hand-held unit with a nice display - i can duplicate the board without the LCD and make it fit the RPI extension header footprint)
Offline DL9SAD
« Reply #142 on: August 22, 2019, 01:31:08 pm »
Hi Joe,
is it possible to get Gerber-files ior KiCad sources of your attenuator PCBs ?
I watched youe video about MiniVNA and was very imptressed. Great job !
Martin DL9SAD
Offline profdc9
« Reply #143 on: August 22, 2019, 02:46:06 pm »
While the gain on the SA612 mixers are temperature compensated, it is not perfect temperature compensation.  Furthermore, unless they used C0G capacitors and the like, the capacitance is also likely to have temperature variation as well.  So for best results, plugging it in and waiting for the device to thermally equilibrate is best for the most accurate results.
Also, you can check out my VNA at
http://www.github.com/profdc9/VNA
It is similar to the NanoVNA, but you can assemble it yourself, and it may offer some advantages in accuracy because I actively lock into the intermediate frequency.  But it still requires a thermal warmup period.
« Reply #144 on: August 23, 2019, 01:23:45 am »
Isolation is better but still poor compared with the Nano.  However, it may be good enough to do something with.   I was hoping that the isolation specs would have been ultra conservative.  If you want good isolation, it seems you are going to have to pay for it.   :-DD
I was looking at the poor input match of the Nano but doubt I will try to do anything with it.   I ran a cal using a 1-150MHz sweep, then repeated the T-check without the switch as before.   It smooths it out a bit, which we would expect with more data points but it's a wash.  Errors I suspect are me not taking care to torque it.   But that mismatch is really bad for running these two port tests.   My guess is most people don't care.  After all, its a $50 analyzer, not $50,000.
I think the thing to do is run the T-check over a 50MHz sort of range using the my full 2-port calibration and see what we come up with.
« Reply #145 on: August 23, 2019, 01:25:45 am »
Hi Joe,
Martin DL9SAD
Sorry, I don't sell any products nor do I open source any code or designs.   I will say that AppCad does have a built in strip line calculator that you may be interested in.  The tool is free to download.
  • Country: ua
« Reply #146 on: August 23, 2019, 08:42:38 am »
some pcb for attenuators and filters, may be it will be useful for you:
https://oshpark.com/profiles/K8VFO
« Reply #147 on: August 23, 2019, 08:26:20 pm »
Picture showing the test setup.
The components for the bias Ts have been added to the transfer relay.   I engraved the copper plate because the steal case is very thin and easy to cut through.
Using the new transfer relay as shown,  I ran a full 2-port cal from 1 to 500MHz and then ran a T-Check.   It's pretty poor but believe it or not, this is much better performance than I saw with the first prototype.
For those playing along, I am using an OMRON G6K RF DPDT relay.  These are about $20 USD in singles.   As I mentioned earlier, it behaves like a $20 relay, not a $600 relay.
Added picture of the setup mentioned.
« Last Edit: August 23, 2019, 10:50:09 pm by joeqsmith »
« Reply #148 on: August 23, 2019, 08:32:59 pm »
I repeated the full 2-port calibration, this time sweeping from 10 to 50MHz.   I'm just wanting to work in a less error prone region.
The attached shows the results of repeating the T check.   Even with this narrow span, we can see it's still +/-8% error.
« Reply #149 on: August 23, 2019, 08:41:54 pm »
This is looking at S21 after the 2-port cal, using the thru standard.
A new reference feature was then added to the software to allow me to easily measure the gain from a 0dB reference.   The second plot is showing the two MidWest Microwave 10dB attenuators attached (shown in the setup picture).   You can find information on these here:
https://www.mouser.com/ProductDetail/Midwest-Microwave-Cinch-Connectivity-Solutions/ATT-0290-10-HEX-02?qs=kRS0rR9cfpUxbNsiwYNf9w%3D%3D
