I'm using a Quectel UC20-E 3G modem.
The operating bands should be 850/900/1800/1900/2100MHz. The PCB size is small, i.e. 31x63mm. I guess that PCB is too small for a ground-dependent PCB antenna like PIFA.
I have found this antenna from Molex
http://www.digikey.com/product-detail/en/1052630002/WM9670-ND/3918565The drawback is price (3$ @ 1000pcs) and it is very big (107mm long).
Can someone point me in the right direction, what antenna type would fit this design? Any recommendation for a particular antenna?
Thanks.
