Author Topic: VNA calibraion kit for MCX/MMCX/UFL genre  (Read 1821 times)
Offline trp806moTopic starter
« on: January 23, 2025, 07:48:09 pm »
I need to test some s11 antennaes integration for some new 5G modem.
I may change the standard SMA for some smaller type (MCX/MMCX/UFL) but as I was looking for a "real" calibration kit for the VNA I notice that the A brand don't have such kit (R&S, Keysight, ..) So do someone know how the supplier of a MCX/MMCX/UFL antenna are testing their product ? Or do i miss something ?
Offline joeqsmith
Re: VNA calibraion kit for MCX/MMCX/UFL genre
« Reply #1 on: January 23, 2025, 10:57:31 pm »
Not that I am aware of.
Offline jbb
« Reply #2 on: January 24, 2025, 05:56:51 am »
The thought occurs that these miniature connectors aren’t designed for a high cycle life. So making a proper cal kit could be a bit wasteful due to limited lifetime.
The following users thanked this post: Qw3rtzuiop
Online EggertEnjoyer123
« Reply #3 on: January 24, 2025, 06:17:19 am »
You could just buy a SMA to U.FL adapter for a few bucks. The 1dB or so difference is probably nothing to worry about.
Offline Miek
« Reply #4 on: January 24, 2025, 10:35:56 am »
I'm not aware of any cal kits for those connectors.
What I do personally for U.FL is calibrate to SMA and then use a good SMA to U.FL adapter. I use the HRMJ-U.FLP(40) and HRMP-U.FLJ(40) adapters, they're designed for test use with lower retention force and a higher mating cycle rating, and they don't have any significant mismatch so you can use port extensions to de-embed them. I wouldn't recommend the cheap pigtails, they usually have some mismatch at the coax connections, so aren't easy to de-embed.
The following users thanked this post: Kean, RoV, trp806mo
Offline hendorog
« Reply #5 on: January 27, 2025, 10:28:04 pm »
The only one I am aware of is this one:
https://www.megiq.com/products/balanced-calibration-kit
Check out my cal kit store:
www.vnalab.net
Offline pdenisowski
  • Product Management Engineer, Rohde & Schwarz
    • Test and Measurement Fundamentals Playlist on the R&S YouTube channel
« Reply #6 on: January 28, 2025, 01:34:51 pm »
Same as the other posters - I have not seen one
Test and Measurement Fundamentals video series on the Rohde & Schwarz YouTube channel:  https://www.youtube.com/playlist?list=PLKxVoO5jUTlvsVtDcqrVn0ybqBVlLj2z8
Offline virtualparticles
« Reply #7 on: January 28, 2025, 09:15:07 pm »
There are no metrology-grade calibration kits for those connectors because the connectors themselves are not repeatable enough. Eggert's adapter suggestion is probably your best bet.
The following users thanked this post: pdenisowski
Offline wb0gaz
« Reply #8 on: January 29, 2025, 09:03:51 pm »
I'd suggest asking Kirkby Microwave (UK) - when I purchased one of their SMA cal kits some (3-4?) years ago, they had option (which I added to my order) for U.FL which ended up being a few adapters and a few short sections of 1.37mm coax, but by the time it got here the need at that point had passed, and I've not returned to U.FL-land so far since.
I believe Kirkby Microwave have iterated on their product since then, and their broad offerings include support well beyond 6 GHz, so they'd likely have device coefficients to support the connector in the frequency range you cite.
