Author Topic: Noisy Wallplug PSUs for the HF receiver  (Read 1224 times)
Offline vinloveTopic starter
« on: March 18, 2023, 04:55:51 pm »
I have a few 12V wallplug PSUs which plugs into the wall AC mains socket, and it gives out 12V DC.
When they are used for the other devices, they are perfect - powering them and making them work.
But when they are plugged into my Shortwave HF Receivers, they are the source of the hash noise in the receiver.
It is very high level of static noise they cause, so that the receivers are not able to hear the weak signals.
Are there known effective ways to clear this problem?  Obviously these wall plug DC PSUs are not the radio's original PSUs, but they are the cheaper OEM made or unknown makes.
Offline geggi1
Re: Noisy Wallplug PSUs for the HF receiver
« Reply #1 on: March 18, 2023, 08:29:51 pm »
Get a PSU with a transformer not a switcher and you are most likely good.
Offline M0HZH
    • QRPblog
« Reply #2 on: March 19, 2023, 09:07:00 am »
You can experiment with choke ferrites on the power cable, but I'd recommend either a linear supply or at least a quality SMPS with proper filtering.
Offline profdc9
« Reply #3 on: March 21, 2023, 03:05:53 am »
On the radio I designed, I included a filter for the input DC voltage, also to prevent radiation of the local oscillator on the power cable.
It consists of a conventional arrangement: two shunt capacitors and a common-mode choke between them.  The two shunt capacitors are tied to separate grounds on each side of the choke.
You could try something similar if you need to filter a noisy wallwart.
Offline M0HZH
    • QRPblog
« Reply #4 on: March 21, 2023, 09:09:25 am »
That is a good step, unfortunately it won't stop EMI radiated by the power cable from the switcher to the input of the radio, which then gets picked up by the radio's antenna. A second choke at the switcher's output could help.
Offline radiolistener
  • Country: ua
« Reply #5 on: March 21, 2023, 12:31:33 pm »
Switching mode power supply is a very bad choice for receiver. Any radio receiver likes linear power supply.  :)
Offline Geoff-AU
« Reply #6 on: March 22, 2023, 04:22:52 am »
Not true.  I have a 13.8V 23A SMPS (Manson SPA8230G) which is extremely RF-quiet (very low EMI).  Everyone in the amateur radio circles loves them.
Cheap and nasty SMPS are obviously going to be EMI generators.
Offline M0HZH
    • QRPblog
« Reply #7 on: March 22, 2023, 12:07:33 pm »
I can confirm, the Manson stuff (and all their rebrands) is good.
