The
surface area of the antenna is what transmits so both length and diameter is important. They do not use wire but 2-3 inch tubing . Sometime even bigger plastic tubes wrapped with foil.
For Rx not much voltage. But for Tx:
Off the cuff, 100 W from a 50 ohm Ham transmitter into a 10 foot dia loop will generate 10K Volts after you match the loop with your transmitter with the appropriate match like a gamma or another small loop. Matching is not easy, either.
Huge amounts of power are transferred back and forth from the "L" to the C" of the Tank circuit.
People have burned holes in expensive 15,000 volt Vacuum Variable Caps.
I built a Mag Loop and it worked just fine for 40 Meters to way over 10 Meters
I do not know how much power your transmitter is going to make. Maybe a few watts?
For Rx any really good cap will do but for Tx you need high voltage caps. They make caps from tubing (Trombone caps for example) and metal plates and use variable caps with big plate distances. Butterfly caps also. You probably need a variable cap for tuning, maybe an old variable cap from an old transmitter would work for low power. These antennas have to be tuned exactly to the resonant freq. The "Q" is very high and tuning is very sharp, as a result of the high Q.
Tuning the loop is important for Tx and also RX. It will do a good job of eliminating nearby and far away frequencies. Again, it is nothing but a fancy very large LC Circuit. A LC circuit is a tuner. In this case a very high "Q" tuner.
Join the Magloop group and read some of the info:
https://groups.io/g/MagLoop/messagesOr this group:
https://groups.io/g/HelicallyLoadedMagLoop/messagesI really do not think that a small loop is a good idea for VLF or ELF. I think it would be way too inefficient.
