In my opinion, there is no short and easy way to get your jammer up and running, no matter how small it is. The reasons are:
- RF and high speed (>= 1MHz) circuit behave in a different way compare to "low speed" circuit. At such extreme frequencies, things like skin effect and reflection become serious and need special design. Those techniques are not usually well understood.
- To overcome such challenges, RF engineers need to have access to special equipment (vector network analyser, precision frequency counter with atomic or GPS-disciplined clock, spectrum analyser, field solver and special simulation software). I don't think that the general public have those "weapons" available to them.
If you still insist that you want it (which is the right attitude when you face any problem), may I suggest:
- 1st: get the oscillator running on a single frequency only. Wide band design adds one more level of complexity over on something that is tough enough. A crystal plus a clock generator (like Silicon Labs any frequency in any frequency out IC) should do the trick.
- 2nd: OK, suppose you have a 2.5GHz sine wave already. You need to emit it out with enough power, which mean you need an antenna and a driving circuit. There are many reference meandered antenna design out there, you should be able to grab one. The driving circuit can be a RF driver like ADL5321. Also, do pay attention on impedance matching. If you don't understand how to do it, nothing will work.
- 3rd: power mangement. Seem silly, but RF circuit have special demands towards power supply circuit.
- 4th: there will still be a lot of traps. Most consumer passive components aren't suitable for RF circuit. FR4 based PCB starts to become lossy at 2 GHz so be careful.
- 4th: whatever you do, be sure not to affect anyone else other than you. I don't want ot be your partner in crime
Hope this helps.
Quang.
