Author Topic: Oxidation on Mag Loop Antenna  (Read 2723 times)
Offline ronschTopic starter
« on: April 10, 2016, 12:31:57 am »
Does anyone know whether oxidation on an aluminum mag loop surface reduces performance over time? I have a Pixel Pro-1B receive-only non-resonant amplified loop antenna that has been in the weather for several years.
Thanks, Ron
K2RAS
Offline T3sl4co1l
    • Seven Transistor Labs
Re: Oxidation on Mag Loop Antenna
« Reply #1 on: April 10, 2016, 04:54:40 am »
As long as it's solid I doubt you'll notice a difference.  Mind possible corrosion of internal surfaces / structures / connections.
Seven Transistor Labs, LLC
Offline AF6LJ
« Reply #2 on: April 10, 2016, 09:38:53 pm »
Since Aluminum oxide is an insulator I suspect there won't be a problem.
Sue AF6LJ
Offline borjam
  • EA2EKH
« Reply #3 on: April 11, 2016, 02:29:56 pm »
Being non resonant it shouldn't be a problem. It might be for a resonant, transmitting loop which requires a very high Q to be efficient. But for a receiving antenna I don't think it will be a problem at all. Moreover, aluminum tends to form a passive oxide layer, it doesn't get deeper as far as I know (unlike other metals like iron).
(Wellbrook ALA-1530+ and MFJ1788 user here)
Offline donmr
  • W7DMR
« Reply #4 on: April 11, 2016, 06:43:31 pm »
In normal air aluminum always has an oxide on its surface but its pretty clear.
Are you seeing corrosion?
« Reply #5 on: April 11, 2016, 06:45:05 pm »
No corrosion is seen.  Just the normal concern is the antenna working as well as it can...
Ron
K2RAS
