Electronics => RF, Microwave, Ham Radio => Topic started by: ronsch on April 10, 2016, 12:31:57 am
Title: Oxidation on Mag Loop Antenna
Post by: ronsch on April 10, 2016, 12:31:57 am
Does anyone know whether oxidation on an aluminum mag loop surface reduces performance over time? I have a Pixel Pro-1B receive-only non-resonant amplified loop antenna that has been in the weather for several years.
Thanks, Ron
K2RAS
Title: Re: Oxidation on Mag Loop Antenna
Post by: T3sl4co1l on April 10, 2016, 04:54:40 am
As long as it's solid I doubt you'll notice a difference.  Mind possible corrosion of internal surfaces / structures / connections.
Tim
Post by: AF6LJ on April 10, 2016, 09:38:53 pm
Since Aluminum oxide is an insulator I suspect there won't be a problem.
Post by: borjam on April 11, 2016, 02:29:56 pm
Being non resonant it shouldn't be a problem. It might be for a resonant, transmitting loop which requires a very high Q to be efficient. But for a receiving antenna I don't think it will be a problem at all. Moreover, aluminum tends to form a passive oxide layer, it doesn't get deeper as far as I know (unlike other metals like iron).
(Wellbrook ALA-1530+ and MFJ1788 user here)
Post by: donmr on April 11, 2016, 06:43:31 pm
In normal air aluminum always has an oxide on its surface but its pretty clear.
Are you seeing corrosion?
Post by: ronsch on April 11, 2016, 06:45:05 pm
No corrosion is seen.  Just the normal concern is the antenna working as well as it can...
Ron
K2RAS
