Author Topic: pa0rdt-Mini-Whip antenna.  (Read 4443 times)
Offline hamster_nzTopic starter
« on: February 21, 2017, 10:15:50 am »
I've had a long term project which never made it to the top of the list to spend the time building- a pa0rdt-Mini-Whip LF/MW antenna, for use with a direct conversion SDR rig.
Interesting because of the small physical size - it is capacitively coupled to the e-field. This also gives it a wide flat frequency response.
The transistor footprint was flipped, but tombstoning three 0 ohm resistors and flipping the transistor fixed that. >:D
I'm yet to get it connected to the SDR (need connector), but had it on a USB scope's FFT as a poor man's spectrum analyser. The local MW stations stood out like the proverbial dogs bollocks vs that of a random length of wire, even without a decent ground reference.
Original design details are at http://dl1dbc.net/SAQ/Mwhip/Article_pa0rdt-Mini-Whip_English.pdf, but built with SMD and some of the parts were substituted (esp the JFETs for the front end).
Oh, I must buy some flux cleaner....
Offline vk3yedotcom
    • vk3ye dot com (radio articles and projects)
Re: pa0rdt-Mini-Whip antenna.
« Reply #1 on: February 21, 2017, 01:06:16 pm »
Interesting project.
Here's my experiences when I built one a few years back.
NEW! Ham Radio Get Started: Your success in amateur radio. One of 8 ebooks available on amateur radio topics. Details at  https://books.vk3ye.com
Offline awallin
« Reply #2 on: February 22, 2017, 03:58:46 pm »
There is an updated cricuit by PA0NHC that uses BF998 for the first FET:
http://www.pa0nhc.nl/Miniwhip/indexE.htm
and also a version by RA0SMS, for sale on e-bay. also seems to use BF998.
http://www.ra0sms.ru/p/the-active-antenna-mini-whip-10-khz-30.html
I just tested the original PA0RDT design against a long-wire (around 35m IIRC), looking at some LF time-code signals. The long-wire has a tuning coil for resonance at 136 kHz - so the comparison isn't entirely apples to apples...
Anyway the mini-whip seems to perform quite well and is significantly easier to find space for than the 35-40m wire!
For the TDF signal at 162 kHz the tuned long-wire provides almost the same signal as the amplified mini-whip.
I also made a ferrite-sleeve-loop, and a ~1m diameter coax-loop, but haven't had time to test them properly. For LF it seems SNR is key and it isn't obvious that a bigger antenna or more gain will help...
The time-code transmitters pretty large installations:
Anthorn, https://goo.gl/maps/nVymTZ7zi8L2
Mainflingen, https://goo.gl/maps/mKD297oE1rq
Allouis, https://goo.gl/maps/K71JtKVVGAz
« Last Edit: February 22, 2017, 04:06:34 pm by awallin »
Offline Wolfgang
    • Electronic Projects for Fun
« Reply #3 on: August 15, 2018, 09:38:31 pm »
Hi, dont worry, these antennas are quite tolerant to sloppy construction.
I made some of them in different sizes, all work OK:
https://electronicprojectsforfun.wordpress.com/antennas/active-antennas/
