I do not have a phase noise analyzer, so analysis of the signal phase behavior was carried out as follows:
the signal under study with the frequency Fin was applied to the ADC input, and
coherent signal with frequency Fs was applied to ADC external clock.
Frequencies ratio Fin/Fs=5/4.
The same phase points (for example, 1, 5, 9, 13, ... etc) of the investigated signal discrete implementation in the absence of modulation
in both signals must fall on the same phase points of the studied periodical signal.
The graphs of the same phase points amplitudes should look like horizontal lines, and the histogram of the amplitudes dispersion
should seems like the law of the random variables distribution (if there are no regular components).
As an example, the results of such an experiment can be given:
Signal under study:
Agilent's E4422B output (Fout=87.5MHz; Urms=707mV) ->
-> ADC (ADS5541) input;
ADC external clock signal:
External output 10MHz of Agilent's E4422B TXCO -> Freq. Multiplyer 7x10=70MHz -> Amplifier -> Quartz Filter 70MHz ->
-> external input of ADC (ADS5541) synchronization;
Please look results in the attached files:
shows the behavior of similar phase points amplitudes in the absence of modulation of two coherent signals.
Total points in the discrete implementation of the signal - 16M.
Figure 2.png -
the histogram of the distribution for 4 same phase points is shown (because with a frequency ratio of 5/4 we get 4 points for "period")
Figure 3.png -
the same histogram for one point on an enlarged scale.
This graph looks like a normal distribution law of a random variable.
shows the behavior of similar phase points amplitudes in the case when the signal under study was taken
from a Chinese synthesizer board based on the ADF4351 chip (during the experiment, it was assumed that the chip was really from ADI)
In the absence of amplitude modulation, this result can be interpreted as a presence of phase/frequency parasitic modulation.
Unfortunately, a mistake was made during this experiment, because low-frequency amplitude modulation was not previously detected
in the output signal of synthesizer. The period of this modulating signal = 0.4 miliSek.
Thus, my interpretation of the experimental result as a presence of parasitic phase modulation in the signal was wrong.
From my point of view, the ADF4351 chip should not have amplitude modulation, but it will be better to move the discussion for this problem to another post
so the title of the current will not be match to new topic.
Thanks to everyone who tried to help me.
