Author Topic: Crystal set frontend - why parallel LC, not serial?  (Read 3852 times)
Offline aneevuserTopic starter
« on: October 09, 2019, 01:12:56 pm »
I've recently realised that I'm confused about something elementary:
Why did the classic AM receiver crystal sets use a design based on an aerial feeding a tank circuit i.e. a parallel LC resonator, as opposed to a serial LC resonator?
My confusion stems from the fact that a tank circuit gives current gain at resonance, but no voltage gain. Given that a crystal set used a diode-based AM demodulator, which we need to drive with at least the forward bias of the diode (say 0.3 V for a germanium diode), wouldn't it make more sense to use a serial LC resonator with good Q, and drive the diode with the voltage across either L or C, which will be roughly Q times the aerial voltage at resonance?
What am I misunderstanding here?
Offline German_EE
Re: Crystal set frontend - why parallel LC, not serial?
« Reply #1 on: October 09, 2019, 05:28:27 pm »
You now have a simple task, build two crystal sets using identical components but with one using a series resonant circuit, then report back,
If it's still available it might also be interesting to try a ZN414 circuit using a series tuned circuit.
Oh yeah, I also have no idea why parallel circuits are always used so I look forward to reading your results.
P.S. The preselector in my ham radio transceiver uses a series resonant circuit
« Last Edit: October 09, 2019, 05:30:49 pm by German_EE »
Warren Buffett
Offline chris_leyson
  • Country: wales
« Reply #2 on: October 09, 2019, 06:35:06 pm »
Simply because parallel resonant circuits are high impedance at resonance and a short antenna, compared to the wavelength, will be high impedance and better matched to a parallel resonant circuit. Later versions of crystal sets had taps on the coil to get a better match to the antenna impedance and some coils were even manufactured with a sliding contact and some crystal set even had taps for matching the detector crystal.
If you're going to use a series resonant tank then you will need to drive it with a low impedance source so some sort of impedance matching network or transformer would be required and that would defeat the simplicity of a crytal set with a parallel tank with optional impedance matching taps.
« Reply #3 on: October 10, 2019, 09:47:10 am »
I see. That does indeed make sense - if an aerial looks like a voltage source in series with large R, this would give dismal Q with a series LC circuit since then \$Q \propto 1/R\$ whereas it would give decent Q with a parallel LC circuit where \$Q \propto R\$
However, I'd be interested in some numbers - what would the typical impedance of say a short wire aerial be? I thought that it would only be maybe a few K ohms at most, though a quick google hasn't given me any specific figures. If so, then that still isn't a very good match to a parallel tank circuit, is it?
« Reply #4 on: October 10, 2019, 09:54:08 am »
I've already done this, and the results are what you'd expect - the series circuit gives a nice big signal at resonance, that drives the demodulator just fine, and the parallel circuit doesn't.
However, I've been driving the LC circuits from a signal generator, so I have control over the signal amplitude, and can get both to work by cranking up the amplitude far enough - that isn't an option when driving them from a real aerial.
Offline hfleming
  • Country: no
« Reply #5 on: October 10, 2019, 10:01:42 pm »
Like others stated, the antenna has a high impedance, >1k.  A parallel tabk won’t load the antenna at resonance, so you will get selectivity at resonace, but a series circuit will load the antenna. If you have an active antnenna with a low output impednace on the other hand, a series tank should work better.
Offline mark03
« Reply #6 on: October 11, 2019, 05:03:30 pm »
I have sometimes wondered about this in the context of tuned receiving loop antennas.  Usually they are designed with a capacitor in parallel with the loop inductance, followed by a high-input-impedance preamp.  Why not put the capacitor in series and make the preamp a transimpedance stage?
Offline szoftveres
« Reply #7 on: December 31, 2019, 06:08:24 pm »
Here's the answer http://www.kennethkuhn.com/students/crystal_radios/antenna_matching.pdf
but I'd recommend all the other articles as well http://www.kennethkuhn.com/students/crystal_radios/
Also, a short antenna is very reactive, an adjustable loading coil (e.g. 30uH - 300uH, a typical ferrite loopstick antenna coil with the ferrite rod out- and fully inserted) can make the antenna tunable and boost the receiver significantly.
Great crystal set experiment and explanation videos:
Offline biastee
  • Country: my
    • 9W2LC
« Reply #8 on: January 01, 2020, 08:05:37 am »
1. Aside from impedance matching as mentioned by chris, the parallel LC also serves as the diode detector's DC ground return.
900204-0
2. the shunt inductor helps to discharge static; important as low-barrier diodes are fragile.
The impedance will vary greatly with wire length, proximity to ground, frequency, and presence of counterpoise, etc. However, if u take IEC315-1 aerial simulation network for a 5m wire as representative, the impedance is 105 - j2181 at 1 MHz.
« Last Edit: January 01, 2020, 08:14:58 am by biastee »
Offline vu2nan
  • Country: in
    • Amateur Radio - VU2NAN - Nandu
« Reply #9 on: January 03, 2020, 05:50:01 pm »
Crystal Radios may be broadly classified as follows:
1. Parallel-tuned, series-fed
The diode-clipped parallel-resonance voltage is output to the phones. High-impedance diodes and phones are required to match the high impedance of the parallel-resonant circuit. This configuration is suitable for reception of distant, weaker stations.
2. Series-tuned, shunt-fed
The diode-clipped series-resonance current is output to the phones. Low-impedance diodes and phones are required to match the low impedance of the series-resonant circuit. This configuration is suitable for reception of nearby, more powerful stations.
3. Series-tuned, shunt-fed variant
This is a variant of the above series-tuned, shunt-fed configuration. Using low-impedance diodes and phones, it delivers identical performance.
Regards,
Nandu.
« Last Edit: January 03, 2020, 06:04:59 pm by vu2nan »
Offline German_EE
« Reply #10 on: January 03, 2020, 07:18:38 pm »
I was wondering when you would notice this thread  :) From what I remember you were the crystal set expert on eham.net. Apart from the rules being slightly different (we prefer posts with information rather than multiple links) you will find a similar group of electronics experts from a wide range of fields plus some newbies eager to learn.
Warren Buffett
Offline vu2nan
  • Country: in
« Reply #11 on: January 04, 2020, 10:11:28 am »
Thank you so much for the warm welcome!
Regards,
Nandu.
« Last Edit: January 05, 2020, 02:40:20 pm by vu2nan »
