Author Topic: pcb loop chip antenna impedance confusion  (Read 778 times)
Offline electronxTopic starter
« on: December 03, 2024, 08:05:28 am »
1001312 I have a 50 ohm 2485MHz chip antenna.
I have to adjust the s11 parameters for the antenna to work at the frequency I want, yes, everything seems fine in this case.
However, when I measure the z11 parameters from the antenna transeivcer feed point, I see a value like 36 ohms.
Shouldn't I see 50 ohms here?
I see 36 ohm impedance at 2.441 ghz, it provides s11 parameters but in this case maximum power transfer cannot be done according to maximum power theory.
in this case when I increase the impedance to 50 ohms, s11 parameters shift towards 2.7 ghz.
Can I keep the s11 parameters at 2.441 ghz center frequency with the correct values ​​and pull the feed impedance to 50 ohms?
« Last Edit: December 03, 2024, 11:27:32 am by electronx »
Re: pcb loop chip antenna impedance confusion
« Reply #1 on: December 03, 2024, 06:23:11 pm »
My mistake, I looked in db. :palm:
