Author Topic: SML VLF Q vs active amplification  (Read 1185 times)
Offline electrolustTopic starter
« on: June 14, 2017, 07:00:28 pm »
I'm novice wrt electronics in general, and pretty much clueless wrt RF.  So excuse me if this is just dumb or if I ask obvious followup questions.
I'm building a 5.5kHz receiver using what I guess is referred to as SML.  Probably not too different than a DCF77 receiver.
If I optimize for packaging, which is important for my final product, I would choose small SMD inductors which have low Q factors at the resonant frequency.  I will (obviously?) need to amplify the signal.  Since I can just actively filter for desired bandwidth at each gain stage, do I need to worry too much about the Q factor of the antenna LC circuit?  My understanding is that the resonant signal peak needs to be above atmospheric and thermal noise floor (important at VLF), so to the extent Q affects the peak amplitude it matters, but beyond that I'm hoping I can pick the best inductor within my packaging constraints and not necessarily optimize for Q.
Offline CopperCone
  • *knock knock*
Re: SML VLF Q vs active amplification
« Reply #1 on: June 14, 2017, 11:53:31 pm »
I'm no RF expert either, but basically the benefit of a prefilter is of course its harder to bring devices to saturation on a rail and cause errors.
It increases robustness to nasties. and being passive, its lower noise. so your op-amp noise has less effect.
