Author Topic: Portable, 2-port 1 MHz to 6 GHz VNA  (Read 12157 times)
Offline stmnvm
  • Country: ru
Re: Portable, 2-port 1 MHz to 6 GHz VNA
« Reply #25 on: December 07, 2018, 06:24:01 am »
Reading data from 0x0 to 0x3fffffff.
To skip bad blocks, and use logical address to read.
To verify spare area data.
There are (is) 1good block(s) with verify errors.
Good block178 contains 2 difference, block address [0x5900000-0x597ffff], with spare area at [0x5dde000-0x5e64fff]
Please erase and program again, because good block contains verify error.
Offline ogden
  • Country: lv
« Reply #26 on: December 07, 2018, 12:30:54 pm »
What you are talking about? Could you give context of information you just provided?
Offline S52E
  • Country: si
« Reply #27 on: January 20, 2019, 01:51:34 pm »
HELLO  IM OLSO INTERESTED FOR MAKING THIS VNA FOR ME  AND PLEASE HOW WE CAN ARANGE FOR CODE THAT YOU CAN SEND TO ME
REGARDS VOJKO DE S52E
Offline BigMark
« Reply #28 on: January 28, 2019, 09:41:50 pm »
Hi all!
There have been very impressive DIY VNA projects around lately, like hforsten, loxodes and xavna which motivated me a lot to do my own little project. Here is the description and first results of my portable 2-Port VNA. Let me know what you think! ;)
For the transformer, you could look at Coilcraft who do all sorts of different designs. They can also supply samples, but you would need to read the small print to see what applies to your country.
https://www.coilcraft.com/
