Hi all,
First of all, -Thank you for this thread! Without it I think I still would be pulling my (lack of) hair in frustration!
Just got a old Icom IC271E with a dead battery on the memory card. Found this thread and have spent almost two days buildning programers and testing back and forth with no luck. First I started building a N2CBU CD4040 programer but ran into trouble getting it to work with the LPT port on my XP-machine (oldest PC I have). Got the same result as many here seem to have gotten, faild to verify the code after writing. Built a Arduiono UNO adapter but no luck there either (think I have something wired wrong on my bread board adapter)
But today I finally managed to get the card programed and the old IC271 is now back in working order!
This is how I finally did it:
- N2CDU CD4040 programer (like in the first post.)
- PC running XP
- The N2CDU program (running in DosBox-X, In DosBox-X , modify the config file with "Parallel1=Reallpt" )
- LPT port set to fixed address in Bios and bidirectional
With these setting the N2CDU programer works perfectly!
On the IC271E I also had to hold VFO/M + CLEAR when first turning it on after I installed the board.
Hope this helps someone spend a few less hours getting their old Icom back on track!
73 de S7UYJ/Roger
