I never did anything with this, but you might be interested to try to find my post about microwave plasma arc welding, which is a super interesting application of this.
I believe its the most "oxy acetylene torch" like electric arc that can be made, but the hand piece leaves something to be desired (machine use only, limits the interest), grounding the work piece has less of a effect when plasma is made this way.
It seemed a bit crazy but when you see that hand held laser laser welders took off, this one looks benign in comparison
the application is sheet metal, and unlike laser welders, it looks like you might be able to have really shitty parts fit up (aka its practical) without laser cut CMM measured parts, so it can realistically be used to repair your typically deformed and warped sheet metal stuff. I kinda imagined with the laser welders taking over, its going to be like "we can do the weld in 10 seconds!" but they will forget to mention 4 hours of fitting work one to set the weld, along with and $25k of fixtures, formers, etc to setup a repair on a cosmetic skin part
but, as far as dead research, microwave plasma arc welding is... mad dead
