Hi xrunner. I am putting together a test bench and looking for attenuators. Was wondering where you got that one.
The 40 dB? Oh I got it from a Chinese supplier on Ebay. You can find others used too that came out of commercial equipment.
I'm working on an old kenwood tr-7800 fm 2 meter radio that has a problem with the squelch circuit, no squelch. I've looked at your post of the tr-740o repair. Thanks for posting that and this one too. Have you ever run into a no squelch problem with a radio like this before? Keep up the good work.
Well I don't have the radio anymore because I repaired it for a friend, and have never touched one either before or since. You'll just have to do the troubleshooting on the bench and follow the schematic. I'm sure you can fix that.
As far as what you asked me in the PM, concerning what test equipment to get, let's talk about it here since there are other members that can input suggestions too. You said you got a DS1045Z. That's great. Some of the items on my bench include -
HP RF signal generator 100 kHz to 1 GHz
100W dummy load
Rigol DS1045Z
Rigol 30 MHz function generator
Rigol Bench DMM
Rigol DS815 Spec. Analyzer w/tracking generator
13.8V 30A power supply for testing ham gear
Two hp power supplies for low current applications
Other selections of various inline attenuators with both SMA and N connectors
Also a whole lot of other test equipment on the side but the above will do a lot of good for you.
