I see the value of checking the antenna. A lot of sellers have no clue about what they are selling and I bet that single frequency, L1 GPS antennas, can very quickly be relabeled, by mistake or intentionally, as GNSS multi-band antennas.
Similarly, some antennas will be better than others...
I do agree that because of the LNA, it will be hard ot measure. But it makes sense to discuss how one could compare there antennas, so they can be compared, and their specs verified.
Sbilf, the issue you are going to face if you do not respect the specifications of the antenna is that you might shift the antenna out of frequency. I would suggest working with the antenna manufacturer, I have been in similar situations before, and often they have useful guidelines for these situations (from "do this XXX and it will fix everything" to "we have no idea" with "if you do what you want to do it will not work" in between)
