Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
RF, Microwave, Ham Radio
RF transformer confused schematic
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: RF transformer confused schematic (Read 2319 times)
kendalll
Contributor
Country:
on:
March 24, 2016, 11:50:40 pm »
I'm confused by the schematic symbol for this RF transformer drawn as a choke. But if you look at the pin names, and the location of the dots, it looks like it's actually a 'standard' configuration transformer. Anyone know why this is? I posted in the RF section figuring maybe you guys might have run into this before.
Does anyone know why it's shown this way in the schematic for the ETC1-1-13?
http://cdn.macom.com/datasheets/ETC1-1-13.pdf
Logged
rfeecs
Frequent Contributor
Country:
Re: RF transformer confused schematic
Reply #1 on:
March 25, 2016, 12:39:00 am »
It's a transmission line transformer balun they are spec'ing like a power splitter. Pin 1 is the input. Pins 3 and 5 are the outputs.
Refer to figure 3a:
https://www.minicircuits.com/pages/BalunApplicationNote.htm
Logged
G0HZU
Super Contributor
Country:
Reply #2 on:
March 25, 2016, 02:01:47 am »
Google for 1:1 "current balun"
Logged
German_EE
Super Contributor
Country:
Reply #3 on:
March 25, 2016, 04:25:40 pm »
The schematic is incorrect anyway because a dot is normally used to indicate the start of a winding. One coil has two starts and the other coil never starts at all.
Logged
Warren Buffett
rfeecs
Country:
Reply #4 on:
March 25, 2016, 04:47:33 pm »
In this case, the dot indicates the polarity. They are calling pins 1 and 2 the primary and pins 3 and 5 the secondary. Secondary dot pin 5 is in phase with primary dot pin 1. Pin 3 is 180 degrees out of phase.
Logged
Richard Head
Country:
Reply #5 on:
March 29, 2016, 06:36:12 am »
The drawings a cock-up. No wonder you are having a problem understanding it!The dots indicate the relative phasing of the windings and there should be a single dot on each winding, not two on one winding.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
