Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
RF, Microwave, Ham Radio
rf explorer upconverter mod?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: rf explorer upconverter mod? (Read 1115 times)
coppercone2
Super Contributor
Country:
on:
May 07, 2022, 05:39:31 pm »
https://www.seeedstudio.com/RF-Explorer-Upconverter-p-2991.html?gclid=Cj0KCQjwsdiTBhD5ARIsAIpW8CLGysHxApbQgSH_xgoxlBUTE9ZTimNf4FbGNuq1fRYbqM-TwWM_1gMaAnDmEALw_wcB
So this fits nicely in my chassis and it does what I want, which is to be able to get HF on my SDR. But my SDR (plutosdr) is 6GHz, and the bypass mode on that upconverter is 4GHz.
Does anyone think that its possible to mod that upconverter to pass 6GHz ok in the bypass mode?
Or does anyone know of a similar product that has a higher frequency range? Not really sure if its the LNA, the switch, the coupling capacitors or maybe the connectors.
My auxiliary empty steel plate that would be used for mounting this is 18.5 x 14.5 cm. I thought it might be possible to do this with modules but its a tight fit.
Logged
arocholl
Newbie
Country:
Re: rf explorer upconverter mod?
Reply #1 on:
May 20, 2022, 04:01:29 pm »
Actually the bypass mode is 6GHz capable, it is designed for 4GHz but has only additional linear attenuation at higher frequencies so may work very well in your setup.
Logged
coppercone2
Super Contributor
Country:
Reply #2 on:
May 20, 2022, 07:20:47 pm »
Ok, it looks like a solid choice then. Might linear attenuation come from low quality passive components ?
Logged
arocholl
Newbie
Country:
Reply #3 on:
May 20, 2022, 09:53:46 pm »
If you check the circuit, there are two RF switches, typically adding this kind of linear attenuation
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
