I have noticed a trend for almost all RF isolators that I come across, where all the specifications are on point when I tune a new isolator, but for a used isolator, insertion loss is often around double the factory specification, despite multiple tuning rounds. All other specifications will still be pretty much on point. For example, a dual isolator with a .45dB specification now will read 1dB. This is not for every used one I have worked on, but multiple.
I believe these used isolators have normally seen years of heat and often abuse, sometimes perhaps getting close enough in range to the Curie temperature, that the magnetic components degrade and thus impacts signal flow. If you have ever been in a non air-conditioned rooftop repeater shack like I have, you know about that added heat factor as well. The increased loss ends up as heat in the isolator and its loads, compounding heating and damage more as time goes on. Older isolators may also have oxidation to internal components I suppose as a cause. Hmm.
What say you? Is there some other reason I am not thinking of?
