I am trying to identify a tube, in particular, if there is now a source of such a tube from China or Russia as these are likely not made anymore in the USA.
The tube is from a 10 kHz - 250 MHz, 2500 W Amplifier Research Model 2500L MII amplifier. It is one of eighteen tubes in the amplifier finals. The tubes are oil cooled as can be seen by the nipples on the top. The amplifier itself dates from the early 1990s.
The tube is marked
"Amplifier Research"
1003787 - 101C
I have also included the schematic. I was not able to find the item in the BOM corresponding to these tubes however.
Are any similar tubes used in amateur or broadcast amplifiers?
73,
Dan
KW4TI
