Author Topic: network analyzer as a reciever  (Read 1194 times)
Offline CopperConeTopic starter
  • *knock knock*
« on: June 19, 2017, 06:14:30 am »
Is there a downside to doing this? My network analyzer is pretty sensitive and fast. (300MHz span).
Plugging it into the IF output. Is there anything I should be aware of?
Offline chris_leyson
  • Country: wales
Re: network analyzer as a reciever
« Reply #1 on: June 19, 2017, 07:42:20 am »
In principle I don't see any reson why you can't use a network analyzer as a receiver. You might need to add extra input protection just to be safe, the phase noise performance and dynamic range will probably not be as good as a receiver and your IF downconverter will need AGC.
