Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
RF, Microwave, Ham Radio
[solved, amplifier non-linearity issue] SAW filter performance at harmonics?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: [solved, amplifier non-linearity issue] SAW filter performance at harmonics? (Read 714 times)
szoftveres
Regular Contributor
Country:
on:
April 05, 2024, 05:26:36 pm »
I've been experimenting with this filter
https://www.mouser.com/datasheet/2/3/AFS915_0w03_TS3-2950334.pdf
I have a comb generator and able to pick out the ~915MHz content. However I've been observing leak-through (-20dBc rel. to 915MHz) at 1.83GHz. The datasheet doesn't characterize the behavior beyond 1.4GHz hence I'm wondering if this is normal?
Last Edit: April 06, 2024, 03:02:18 am by szoftveres
Logged
ch_scr
Frequent Contributor
Country:
Re: SAW filter performance at harmonics?
Reply #1 on:
April 05, 2024, 06:00:12 pm »
Just add a single wide LC filter to add the inteded characteristics. Horses for courses.
Logged
szoftveres
Regular Contributor
Country:
Re: [solved] SAW filter performance at harmonics?
Reply #2 on:
April 06, 2024, 02:36:59 am »
I have an amplifier right after this filter which I thought was linear at this power level - that's the culprit.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
