Author Topic: Schlumberger 4017 Stabilock from 1986  (Read 3393 times)
Online MTTopic starter
  • Country: aq
« on: May 10, 2016, 07:51:22 pm »
Found this Schlumberger 4017 Stabilock in a local junk yard. Have not turn it on yet, will open it up to make a inspection first, is it wort spending
time on this boat anchor?
« Last Edit: May 13, 2016, 12:30:32 pm by MT »
Online wkb
Re: Schlumberger 4017 Stabilock from 1986
« Reply #1 on: May 10, 2016, 08:59:25 pm »
I for one would try to get working...
  • Country: aq
« Reply #2 on: May 12, 2016, 05:38:51 pm »
Clean inside, staggering amount of trimmers, counted to 46-47 powers up, beeps, crackles and burps a bit, but after settling down some signals.
Edit: found schemo for 4010, 4020 4021 4022 quite straight forward machine, i save the 10Mhz ovenized crystal reference and junk the rest.
« Last Edit: May 13, 2016, 12:29:27 pm by MT »
« Reply #3 on: May 15, 2016, 06:53:17 pm »
Keep those decade switches, they are quite useful at times, especially make sure to use a wire to keep the whole assembly with the end pieces and spacers together. They can be BCD, reverse BCD or even 1 of 10 selection depending on the model. Quite useful at times to do selection of data or for selecting data that can change occasionally.
  • Country: aq
« Reply #4 on: May 16, 2016, 03:02:21 am »
yes, thanks for the reminder! :-+
Offline nanofrog
« Reply #5 on: May 16, 2016, 03:11:20 pm »
The rotary switches and pots on the front may be worth keeping as well.
Offline German_EE
« Reply #6 on: May 16, 2016, 03:54:11 pm »
I'd try to get it working as well, you could build a complete radio service bench around an instrument like that and it seems a shame to scrap it.
Warren Buffett
Offline CJay
« Reply #7 on: May 16, 2016, 05:04:25 pm »
Oh that's a real shame, it'd be a great piece of kit if you were into radio repair, servicing or homebrew.
I'd have been very interested in buying it as faulty if you were in the UK
  • Country: aq
« Reply #8 on: May 16, 2016, 07:47:55 pm »
Alright, its a shame, so i keep it as is....... for now. :).....It do work, i just dont have time for it right now so i put into storage.
